i want to convert string to 1-D array to input it to waveform graph?
thanks in advance
Message 1 of 18
(3,656 Views)
Hi oiuuhjoi,
ok, and where's the problem?
Spoiler
Ever tried SpreadsheetStringToArray?
Message 2 of 18
(3,654 Views)
hi GerdW
what block should i use?
Message 3 of 18
(3,650 Views)
it's not a 'block' - it's called function... And did you read that spoiler?
Message 4 of 18
(3,647 Views)
hi
i  connect my output string to spreedsheet string input(not format string input) and out to waveform graph
but thats error occure:-
"One or more required inputs to this function are not wired or are wired incorrectly. Show the Context Help window to see  what the connections to this function should be."
what shall i do?
Message 5 of 18
(3,645 Views)
just do what the error says: Open the context help and read it...
Message 6 of 18
(3,643 Views)
how can i make the output 1-D array????
the spreadsheet string array onla accepts 2D array.
Message 7 of 18
(3,636 Views)
You can use Index Array to get the 1 row or 1 column out of the 2-D array that makes up your 1-D array of data.
Message 8 of 18
(3,630 Views)
Or you can create a 1D array with that function! It also accepts 1D arrays...
Message 9 of 18
(3,628 Views)
No it really doesn't. You need to follow Gerd's (very patient) advise and read the help file for the function.
To make the function accept a 1-D array you have to wire a 1-D string array constant to "Array Type".
-CC
p.s. You'll also need to specify the format you want the string to be converted to.
"If anyone needs me, I'll be in the Angry Dome!"
Message 10 of 18
(3,626 Views)
