i push a button
i push a button and i want that some process wil start in labview . it should be like i press keyboard and interupt sent.
now it is implemented using for loop that alwayes check if the value of the button is one
Message 1 of 8
(3,557 Views)
If LV7, use event structure
Message 2 of 8
(3,539 Views)
This sounds like it would be better handled by a case structure and wiring the push button into that.
Amateur programmer for over 10 years!
Message 3 of 8
(3,537 Views)
This calls for an event structure. Have a look at the online help and browse the examples (for example "New event handler.vi") for details.
In your case you would define a "this VI" event for "key down", then determine from the event terminals which key was actually pressed and act accordingly.
Good luck!
Message 4 of 8
(3,535 Views)
If this is a button on the front panel, then everyone's comment about an event structure is correct. If this is some physical button someplace, could you provide more details?
Message 5 of 8
(3,526 Views)
yes for example two buttones one push i take signal from channel one display it and the red light on
second buttone pushed i take signal from second channel green light on
Message 6 of 8
(3,516 Views)
this button connected to the two pins device pci dio 6503
Message 7 of 8
(3,515 Views)
If not time critical (~100msec), a while loop with a delay in it should suffice
Message 8 of 8
(3,511 Views)
