i m using 1 counter so how timer overflow can be avoided?
for my application to measure the time duration using hardware counter, i m using 6602 -32bit 8counter card.
i have to use only 1 counter to measure the time duration, but with 32bit counter i can count 216ms time duration, after that overflow will be started. with second counter i can avoid it easily, but i dont have to use 2 counter so, how programtically i can do that........
Kidnly guide me on that...
waiting for ur reply.
PRASHANT SONI
SOFTWARE ENGINEER-LabVIEW
(2,846 Views)
Hi Prashant,
when you don't want to use a second (HW) counter you should count the overflows in software...
(2,825 Views)
but it is the requirement bcoz other counter is already engaged so i don't have any unused counter .......i want to use some software logic to avoid overflow.
PRASHANT SONI
(2,815 Views)
so how i can do it with software.....if have any sample VI...than please share
PRASHANT SONI
(2,814 Views)
Hi Prashant,
"if have any sample VI"
No, don't have.
but:
- IF "overflow occured" THEN count++
- "overflow occured" when actual count < previous count (assuming you always count up)
(2,809 Views)
