i have wireless phone with serial port ,connected to USB port of computer.How can I read data from phone?
I want to read text data from a wirless phone having 9 pin serial port connecter,other end is connected with USB port of computer for internet connectivity.I have LabVIEW 8.2 and want to read text messages from phone set.How  can I use device address string in VISA Resource Name Control?
Message 1 of 24
(4,267 Views)
That really isn't enough information to go on.Smiley Surprised  First you'll have to figure out how the device shows up in your PC.  When you connect the cable, does it show up as a COM port or something else.  Look in Windows Device Manager.
Once you figure out how it connects, you will have to look at what kind of command set the phone uses.  Does the phone provide an advanced manual or communications manual that lists the commands?
Message 2 of 24
(4,260 Views)
Thanks for reply
When the device is connected to the computer USB port the following devices are displayed in Windows device manager
a.     Multi Port Serial Adapter
b.    TIUMP USB Serial Port (COM3)
In properties their details are,
Device type                              Multi Port Serial Adapter
Manufacturer                            Texas Instruments
Location                                   Location 0 (TUSB3410 Boot Device)
Device type                              Port (COM & LPT)
Location                                   TUSB3410
Note: The device also uses internal HuaWei Wireless modem manufactured by   HuaWei Tech Co.Ltd
Waiting for your kind reply.
Regard Fahim
Message 3 of 24
(4,232 Views)
Fahim,
Raven's right, you need to find out the commands which your phone uses. Then you can use the serial vi's (in the Instrument I/O palette)
You can use *IDN?\r\n (an universal command) to query your device.
Van L
NI Applications Engineer
Message 4 of 24
(4,187 Views)
Thanks Sir!
Error -1073807298 ( VISA:(Hex 0xBFFF003E) could not perform operation because of i/o error) occured while using NI-VISA function by querying the instrument through *IDN?\r\n command.
I am newer  in LabVIEW and want to learn instrumentation by playing instruments through LabVIEW.
Regard Fahim
Message 5 of 24
(4,150 Views)
The *IDN? command is fairly universal among instruments that are also made with a GPIB interface. Its not common at all among other serial connections. You have to get a set of commands from the maker of the phone in order to communicate. Otherwise you would be just wasting your time trying to send a bunch of strings that the phone does not recognize.
Message 6 of 24
(4,146 Views)
Thanks for reply
you mean that it is not necessary that *IDN? is recognized by each and every Serial device.It means that we can not query black box devices (devices which have no programming commands available to the users).
Bundle of thanks ,I hope you will guide us in future too.
Regard Fahim
Message 7 of 24
(4,128 Views)
Have you test AT Commands with your phone?
Raymundo Cassani
Message 8 of 24
(4,111 Views)
@fahim wrote:
Thanks for reply
Regard Fahim
Yes, serial devices can use any and every protocol the developer would like and frequently do so. Your device being a mobile phone there is a chance that it is using the ETSI standard for GSM devices which is based on the Hayes AT command set.
The only problem that bothers me a bit is the error you see when trying to write "IDN?" to your device. That error does not show up because the device does not understand the command but because there is something more basic that goes wrong. The first challange will be to figure out baudrate, data bits, parity and HW handshaking. One of these parameters being wrong will simply give you all kinds of weird errors.
Then you can start to try to send AT commands such as ATZ<cr><lf> which resets the device and should return an OK response.
Rolf Kalbermatter
Message Edited by rolfk on 04-06-2008 09:31 AM
Rolf Kalbermatter  My Blog
Message 9 of 24
(4,105 Views)
Hi.
Use the command:         AT<CR>
If your device response "OK" your device supports AT commands
Raymundo Cassani
Message 10 of 24
(4,074 Views)
