取消
顯示結果
搜尋替代
您的意思是:
i have conected webcam with myrio and i found following error.please suggest what is the error..
oh..sorry sir..under myrio it is not showing...in pc only it is showing
0 積分
11 條訊息(共 18 條)
1,895 檢視
Did you connect your camera to the USB port of the myRIO?
(blog)
0 積分
12 條訊息(共 18 條)
1,881 檢視
actully currently i am using my laptop webcam sir.
0 積分
13 條訊息(共 18 條)
1,877 檢視
can it work with laptop webcam sir...?
0 積分
14 條訊息(共 18 條)
1,870 檢視
Hi sagar,
so the webcam is NOT connected to your myRIO, but you expect the myRIO to detect it?
Similar question: do you have access from your laptop to a webcam in your collegues computer? Think about it…
0 積分
15 條訊息(共 18 條)
1,859 檢視
so sir is there any way that i can use my laptop webcam under myrio or i must have to purchase a usb webcam?
0 積分
16 條訊息(共 18 條)
1,840 檢視
You could write two LabVIEW programs, one on your computer that accesses the webcam and makes the images available over TCP/IP or some other remote access means and the other on your myRIO that reads the images over the remote access connection from the first program. If this sounds complicated to you then you might be right but it is doable.
But the cheapest solution definitely will be to buy an USB webcam. They can be bought for less than what 10 minutes of work time of anyone who has participated in this thread to help you would cost.
Rolf Kalbermatter  My Blog
17 條訊息(共 18 條)
1,814 檢視
ok...thank u all for your very helpfull support.thanks s lot.
0 積分
18 條訊息(共 18 條)
1,792 檢視
