i am using the function generator example
so i did according to your suggestions. but now first iteration appears and immediately disappear. then the graph stays blank. i am sending you my example. please tell me what wrong i am doing?
regards
Message 11 of 12
(479 Views)
Your vi looks OK. I can't run it myself because I don't have an AIO board. I suggest that you turn on the execution highlite and look at the execution flow while it is running. Maybe you are having an error condition somewhere that stops the loop. Use probes to see the data at certain points. You will have to troubleshoot this one on your own. It will give you good experience. Sorry I can't help you further.
- tbob
Inventor of the WORM Global
Message 12 of 12
(479 Views)
