i am trying to detect signal peaks (derivatives of the peaks both +ve and -ve peaks). simultaneously 2 peaks detectors are running, 1 for +ve and other for -ve peaks.
i am trying to detect signal peaks (derivatives of the peaks both +ve and -ve peaks). simultaneously 2 peaks detectors are running, 1 for +ve and other for -ve peaks. when a peaks get detected it would trigger a pulse of approx 1 sec duration and at the same time it would disable the other peak detector for 1 sec time duration. after the time period, again both the peak detectors would be enabled. i have been able to detect both peaks but still not able to control the detectors block the way mentioned before.
the code and the data are attached.
Message 1 of 1
(2,328 Views)
