i am receiving the data through the rs232 in labview and i have to store the data in to the word file only if there is a change in the data and we have to scan the data continuasly how can i do that.
i am receiving the data through the rs232 in labview and i have to store the data in to the word or text file only if there is a change in the data. I have to scan the data continuasly. how can i do that. I was able to store the data into the text or word file but could not be able to do it.  I am gettting the data from rs232 interms of 0 or 1.  and i have to print it only if thereis a change in data from 0 to 1. if i use if-loop , each as much time there is 0 or 1 is there that much time the data gets printed. i dont know how to do this program please help me if anybody knows the answer
(2,935 Views)
Please tell your problem clearly. post any VI you made myself or any one who knows good will modify according to your need
Smiley Wink
(2,931 Views)
I have attatched the vi.  Here in this it receives the data from rs232 as string and converted into binery. and indicated in led also normally if the data 1 comes then the led's will be off.  suppose if 0 comes the corresponding data status is wrtten into the text file.  But here the problem is the same data will be printed many number of times.  so i have to make it like if there is a transition from 1 to o then only print it once.  how to do it.  I am doing this from few weeks please reply if you know the answer immediatly
thanking you
(2,900 Views)
