hyperlink to a html report
Hi ,
I`m using LV2009.
I have simulated a test report of a test board and generated a HTML report in the VI. The generated HTML report is saved in the file in some folder in the hard drive.
All I wann is the hyperlink to the HTML report in the front panel.
I saw few posts in the forum on the hyperlink but majority dealt with the excel sheets.
Looking forward for your solutions.
Manoj
Message 1 of 8
(3,702 Views)
I don't think you can put a hyperlink directly on frontpanel, but you can program a button or other control to open your report on IE as shown in http://zone.ni.com/devzone/cda/epd/p/id/3741
Message 2 of 8
(3,679 Views)
You can use a string indicator and the Mouse Down event to open a URL using the system's default browser.
Example "About" box VI with URL below (LV 2012)
Message 3 of 8
(3,667 Views)
Accepted by topic author Manoj90
Sorry, didn't see the 2009 in your post. Attached as LV 2009
Message 4 of 8
(3,656 Views)
Dear Phillip Brooks,
Thanks for the solution Smiley Happy
I want to extend my VI.
I`m thinking of publishing my VI using web publishing tool. Before publishing labview will ask for the header text and the footer text right?
In the header text, I`m thinking of inserting the hyperlink for the report in the header text, but for that
1. I need to generate the report and save it in the default NI Local web server i.e "C:\Program (x86)\NI\Labview 2009\Local\www" and give this address in the header text.
2. While generating the report, I need to give the above the link in the path but LV is showing error as "no space allowed in the path" ie between the Program and (x86).
Looking forward for the solutions.
Regrds,
Manoj
Message 5 of 8
(3,607 Views)
Thanks KateSmiley Happy
Message 6 of 8
(3,605 Views)
Hi
Spaces are not allowed in web URL's, replace all spaces with %20 i.e. escape your string and you should be good to go
Mike
Message 7 of 8
(3,597 Views)
Message 8 of 8
(3,578 Views)
