http://sine.ni.com/apps/we/niae_asc.main
What is the maxumum number of plots allowed on an Xy Graph? I need 17, but I get an error if I name more than ten.
(2,525 Views)
I don't know the maximum, but if there is an explicit one, it's much larger than 10. It seems like there must be some other problem that is causing the error.
What error are you getting? Which subVI or node is generating it? Could you attach your VI or a stripped-down example to a reply so that we can take a look and see what the problem might be?
John
(2,515 Views)
