html table color
I have a table indicator with various color output by a sub-VI, I want the same table with the color output to an HTML report. I append the table to the report, but it doesn't have the color with it, just the contents. The only way that I can think of to do this is to use append image. But I want to append the table, not the image. Is there anyway to append the table with color on the html file? Thank you.
(2,954 Views)
another way is to go deep inside the "Append text/numeric table to report.vi". Try to find the place where the table HTML TAGs specify its style or style of cells. Then add there your code to change the color. I understan that it's not easy, but it helps.
Good luck.
Oleg Chutko.
(2,954 Views)
Hi.
Oleg's answer is correct. There is a way to do it, but it will not be straight forward and the modification is not supported by NI. Color can be added to text using html coding. I would suggest using google to find the proper syntax for coloring table cells.
-Erik
(2,954 Views)
