hp871x Measure.vi
Hi.
I'm programing the Agilent 8714 Network analyzer. It is quit old equipment.
I have two sets of drivers VXI & LabView.
I have a stacking problem with the VXI. So I have to use the Labview set.
Unfortunately this set miss the hp871x Measure.vi, which is critical.
This Sub Vi allow me to set channels (S21, S11 etc).
I tried to use Programming guide, but the command I've found there is not accepted by equipment.
Please help me with this issue. Maybe I have a grammary mistakes in the command?
SENS[1|2]:FUNC ‘XFR:S 1,1’;DET NBAN; *WAI
If so what is the right form?
Message 1 of 13
(4,015 Views)
Hi underdog
on the  front panel you can access a sub menu to enable the GPIB commands to be echoed !
This means you can actually see when you press your menu buttons what the GPIB command is!!Smiley Wink
The GPIB echo access is,if I remember correctly, with the menu to set GPIB address etc.
Once you have enabled  feature , then play with it, for example carry out a full 2 port calibration !!Smiley Mad
You might have to keep repeating the buttons commands so that you can see record the actual GPIB command.
I have some vi's for the 8714, unfortunayely not at work  - i try and dig them up this eveningSmiley Wink
Well you should be able to come a little bit further now!!!
PS I recognise the command you are attempting to activate  I think you need to remove the [ ] brackets from the sense command... Could be wrong
as its several years since I've used 8714 Network analyser
chow
XSEADOG
Message 2 of 13
(4,004 Views)
Xseadog,
Thank you very much for help.
If you have a sub Vi it will be great.
According the command - that is not a problem I've played a lot with Grammary there.Smiley Happy
I'll try to use your advice to monitor the command.
Message 3 of 13
(4,003 Views)
As promised  the 8714 llb
Hope it helps
 xseadog
Message 4 of 13
(3,995 Views)
Hi.
Unfortunatly, it doesn't help. This miss the "Measure" functions (steting channels to S measurements)- exactly the problem.
I've tried to monitor the VXI sub.vi using the NI spy & I received the command, but when I tried to give it in visa write it has no effectSmiley Sad.
Message 5 of 13
(3,989 Views)
Hi Underdog
I don't quite understand your problem ?
Could you please clarify what you mean !
IF you can read the waveform(graph) from each mode then you can find your S parameters at desired frequency
Remember a picture reveals a thousand lines of code !!!
Upload a png / jpg of problem
chow
xseadog
Message 6 of 13
(3,987 Views)
Hi xseadog.
I wasn't so clear I'm sorry.
The hp8714 network have two channels. Each channels can be set as S21 - Fwd Transmission, S11 - Reflection Port1, S12 - Rev Transmission and S22 - Reflection Port2.
My problem is to set it. In VXI drivers I have a hp871x Measure.vi, which is doing it. It is attached to this message. Howerver the VXI drivers made to me sevral problems  & I need to use NI Labview drivers. This function is missed in drivers that you sent.
Thank for all you are doing to help me.
Message 7 of 13
(3,985 Views)
Hi Underdog
port 1       port 2
   S11       S21
port 1       port 2
   S12       S22
First let us agree that if you have two terminals then there are only 4 solutions
You can connect from port 1 to port 2 and measure the forward gain S21 or the reflection S11
Connection from port 2 to port 1 measures 'reverse gain' S12 and reflection S22 Smiley Wink
If you have the programming guide for the 8714 network analyser then it is possible to do what your C dll is doing!!!Smiley Surprised
If you have not got a hard copy then search  agilent's home page for 8714 network analyser.
In appropiate sub menu you'll find following:
Users guide Part No. 08714-90012 from June 2000
also programmers guide Part No. 08714-90015
chapter 6 has salient info
if you provide your emailaddress I can forward the pdf files if your having trouble
Please clarify what you actually mean with regard to 'my problem is to set it*
Do you mean total set up?
ie set up calibration,frequency parameters- power parameter, number of points,sweep time, markers etc
if necessary please provide pseudo code
we'll getthere in the end
xseadog
Message 8 of 13
(3,979 Views)
O'K.
We are getting closer.
First, I do have the manual and the command I found there is wroten in the top message. It has no effect on the hp8714, or my gramary is wrong.
Now, the equipment has two ports (HW) & two channels (SW). For example to measure Gain I connect UUT input to port1 & output to port2, then I set channel1/2 to S21 (Transmission in hp8712). To measure return Loss I have to set channel1/2 to S11 (Reflection in hp8712). That is exactly the point. I can't set the channels, I still do it only manualy.
Message 9 of 13
(3,976 Views)
Hi xseadog,
I'll try to be more clear.
In fact I look for something that can replace the VXI driver that I sent in previous message.
Message 10 of 13
(3,975 Views)
