hp54616C labview program
I have a question.
in my program, I get the following error.
Error -1073807339 occurred at VISA Read in LHP54601A/602B Read Waveform.vi->MHP546XXX Acq.vi->Ascan9.vi->Run_Ascan.vi.
Possible reasons:
VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
is there anyone has the similar case?
and tell me how to solve the time expired problem?
thank you
(2,888 Views)
The first thing I would check is if the getting started application is able to capture a waveform. If it does you are probably missing some configuration parameter on your VI.
If not, check the trigger level. I had a similar experience with a tektronix scope where the trigger was not properly set for the signal. The scope never acquired the signal and the read timed out.
Hope this helps.
DiegoF
National Instruments.
(2,888 Views)
I solved the problem ,using
case construction and time delay.
it works,but it is a straightforward
stupid method.
thank you.
(2,888 Views)
