hp34970a read vi doesnot wait for scan to finish
I never noticed that your Read is inside a for loop. I'm not sure that is correct. I think you should be able to do a single read and get the results from all scans. Like I mentioned once before I think, I no longer have access to the instrument or manual. I used them for years so I'm going on memory.
Message 11 of 15
(1,006 Views)
I want to get the reading as soon as it scans.. so i set the trigger such tht it scans once and wait for instrument to finish scan and then read it... i want to repeat this...so i used a for loop...each time the reading goes into a 1d array and i did necessary action on the readings in the 1d array.
Message 12 of 15
(999 Views)
yes, we can do a single read and get the readings once of all, but as i need real time readings i kept the read in the loop....
Message 13 of 15
(998 Views)
That makes no sense to me.
Message 14 of 15
(994 Views)
Waiting for the OPC bit to be set is a standard way to do it, but there is an alternative that uses less code and is also standard.  That is, using the *OPC? query appended to your command.  Instead of having to loop to read the OPC bit, it simply waits until anything (usually a "1") is sent to the read buffer.  As far as I know, any equipment that can do the OPC bit set can do the *OPC? query as well.
Here is a picture and a VI with connected terminals.
Bill
CLD
(Mid-Level minion.)
Message 15 of 15
(981 Views)
