hp 428xa conductance
I am using a Labview program to get data from a HP4284A LCR Precision Meter. Currently the capacity C and D (that is a loss factor I think) are measured. I want to change the measurement so that C and G (the conductance) are measured. It is possible to do that directly at the hp4284a, but I don't know where to define that in the Labview program. Can someone help me?
              Stefan
(3,336 Views)
A simple fact, but I'll throw it out there: isn't conductance just
1 / Resistance
 so you could get your R values, do 1 div R, and get G?
(3,334 Views)
ok, but I don't know, how to measure the resistance, neither. Is D the loss factor and can I calculate R from it?
(3,328 Views)
D is the dissipation factor and the relation between R (or ESR Equivalent Series Resistance ) and D can be  seen in the following article:
http://wiki.xtronics.com/index.php/Capacitors_and_ESR
I hope it can help you
Best Regards
Andrea Perin
Application Engineer
(3,304 Views)
You are messing up the terms see here
http://en.wikipedia.org/wiki/Admittance
I do not mean to be patronizing. But then using any measure equipment or software it is very important to have at least some knowledge about the theory behind your measurement. You must be able to evaluate your measurement results.
Message Edited by Coq Rouge on 07-31-2009 04:47 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,298 Views)
