how user define matlab function will work in labview
Hi all
iam trying to implenet the matlab function which i have wrote in Matlab 7.9(R2009b)
 function [ op ] = myimplement( ip )
 the file is attached below
i want to use  matlab function in labview ,i have tried Matlab script node but few of function define in matlab function are not working properly
so is any alternative way to implement matlab function in labview environment to implement my algorithm & getting same results
thnaks
waiting for kind reply
iam trying from many days but not geting any results
Message 1 of 8
(4,355 Views)
When LabVIEW launched Matlab, it's simply calling Matlab and sending it the script. It's really dependent on Matlab to find the function, not LabVIEW. Have you configured Matlab's search path so that it can find your function?
Message 2 of 8
(4,340 Views)
hi
i have used matlab script as well
or math script window
but it is not reading function?
it run the matlab scripts server
a matlab window open when i run script
my problem is that i want to implement the matlab function which is writen in matlab    & iam running it in simulink file
simliar way i want to run it in lab view
if u want i will send u my matlab code
iwant to implement it in labview
 thanks for ur replay
Message 3 of 8
(4,327 Views)
hi
iam geeting problem if u see my attached file
iam using n=ip(1) ..
while running matlab script node
in lab view
is any other way to implement  the user define function in lab view
one way i read is to make dll file then call it from labview
but iam still facing to problem to do
is any one can help me
thanks in advance
Message 4 of 8
(4,319 Views)
You did not attach a file. Did you intend to attach a new file? Was it a VI? What is this "problem"? We are not mind readers. Please explain what the "problem" is. Is it an error? If so, what is the error code?
As for user-defined functions, I have already explained to you that this is a Matlab issue, not a LabVIEW one. Instead of using a function you can copy the inside contents of the function and put that into the script node and pass in the variables through the script node.
Message 5 of 8
(4,290 Views)
Hi smercurio_fc nd sry if u mind my double post actually iamin last month of my post graduate research so i want to complete it urgently
iam attaching detail file what iam facing?/
same thing iam doing in Matlab & getting result but while doing in Labview by using Matlab script node not getting
error 1048 is occured
iam attaching word file kindly help me out regarding that problem
i will be thankfull for u
tc
Message 6 of 8
(4,280 Views)
Why are you feeding yk and zk to the script node? Those variables are not inputs to the function - the function calculates the values. The function has an input called ip, which is a vector.
Message 7 of 8
(4,256 Views)
i have used ip as input but still not getting result
is u know any other method to do that task
thanks
Message 8 of 8
(4,231 Views)
