how use System exec.vi...
hi,
i want to run a shortcut from a labview application. i know the command line to do this from MS DOS but i don't understand how works System exec.vi.
Could you help me giving some example?
Thank you
(3,085 Views)
Use the command "start <path to shortcut>", or "cmd <path to shortcut>", as explained in this document.
Message Edited by smercurio_fc on 06-08-2007 09:46 AM
(3,073 Views)
Correction: "cmd <path to shortcut>" should be "cmd" for the command, and "start <path to shortcut>" for Standard Input.
Anyway, it's explained in the document.
(3,067 Views)
thank you. it perfectly works now!
(3,056 Views)
