how to zoom the value on chart?
hi,
i am using chart control, i deactivated autoscale. but i want to zoom my data, i mean want to reduce the x. scale division... how to do this...?
labview 8.6
Balaji DP
(2,522 Views)
You can directly edit the numbers on the x axis if you want - click and type. As long as autoscaling is off, you will get a resized graph.
You can do this programmatically using the XScale.Range property node.
Alternatively, have a play with the magnifying glass icon on the 'graph palette' of the graph. (Right click the graph, visible items, graph palette)
Ian
(2,515 Views)
