how to write this matlab code in labview?
for those who can program both MATLAB and LabVIEW, how can I write this MATLAB code in LabVIEW language?
% Druckmessung
global druck_analogin druckw WertSYS druck_mmHg_8 handlescurrentPressure
druckwert_u16_vektor = [];
t1 = tic;
druckwert_u16 = druck_analogin.read_u16;
% Wert auslesen
druckwert_u16_vektor = [druckwert_u16_vektor druckwert_u16];
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
pause(0.1);
% Wert auslesen
druck_u16_mittel = median(druckwert_u16_vektor);
druck_mmHg_8 = round((druck_u16_mittel-29974)/43.09);
% Umrechnung mmHg
set(handlescurrentPressure,
'String',[num2str(druck_mmHg_8) ' mmHg']);
t2 = toc(t1);
fprintf(
'Dauer Auslesen: %d s.\n',t2);
I'll be thankful if someone can help as I'm bad at coding and don't quite get how does this function work!!!
thanks!
(2,701 Views)
Hi Valdi,
You can use a math script node, it should be in the structures palet and should look like a blue box. You can just copy and paste your .m scipt into the box see this link
Regards
Andy
_______________________________________
"To 'G' and not to 'C', this is not a question!"
(2,663 Views)
