12-09-2005 12:11 AM
Nishant Desai
12-09-2005 03:34 AM
12-09-2005 05:35 AM
Thanks Chilly,
Its a really fantastic idea, and it works for me too, but the thing inside was every time once it writes the heading and then it write the data again after that it wirtes the heading and write the data, but i ve copup with dat and i ve modified the vi which u ve given to me, i am attaching that vi to with this.
wat i ve done is just putting the write to spreadsheet data vi into the while loop and other all are outside the while loop, which makes the heading to write once and data to write continuosly.
Thanks & Regards,
Nishant Desai
12-09-2005 07:44 AM
12-09-2005 08:06 AM
@chilly charly wrote:
Glad you found your solution. While we are here, could you explain how the .gif animated icon was inserted into your question ?
Looks like it was an image from another website.. this is the URL http://forums.lavausergroup.org/style_emoticons/default/frusty.gif so you take that URL and use the insert Picture Icon on the reply and you get this:
12-09-2005 09:58 PM
Absolutely Mr. Jeff,
You are absolutely right, i ve taken that .gif image from the lavausergroup site, but not the way you told, i just have taken that icon into the lava usergroup question and just copy paste it into the NI question. it als o can be done the way you suggest but it is somewhat tedious coz it takes some more time to link.
Nishant
12-09-2005 10:08 PM
Dear Chilly charlie,
Thanks, Can you please tell mr ur name and your personal contact details, here der is no facility to send personal messages, but if you are member of Lavausergroup, dere is d facility 2 send the PMs, so dere also my usernamr is nishantd so u can send me ur details, if u r not,please become d member, that is also d good site, 4 problem solution.
Nishant
12-09-2005 11:25 PM
Hey Chili charlie,
Can you do one thing for me? can you please attach the time in the Numerical format in the spreadsheet file after the data in the file in the each row???????/
Nishant
