how to use parameterized query for select and display the data in front panel table
Hiiiiii
I am using acess 2007 database
I want to select the the specific  data in database using string control like "Select Product,Dimension,Weight From ProductInfo where Barcode(string control)=?"  and also display the same in front panel table.
I am using Database connecting toolkit.
I saw the example of parameterized insert but it didn't help to use parameterized select query and also to diplay data of parameterized select query.
I looked for example on parameterized select query but i didn't get any.
So pls guide me how to do this. I would like to know other method(if any) than using  parameterized query to perform same.
If possble pls share a reference vi.
Thank you!!!
(3,540 Views)
The lack of this comments Might be because of the broad nature of your question. lets break it down.
What you are describing is defiantly possible: see the links below:
http://digital.ni.com/public.nsf/allkb/8BDBCD17DD091B788625772300757446
http://digital.ni.com/public.nsf/allkb/1D5EB4DCBD13106486256B9D005E11B0
https://decibel.ni.com/content/docs/DOC-11448
I would suggest getting the first few steps off the ground (connecting, displaying in an unideal display) then posting your incomplete work here with a more specific question.
Or hire me to do it 😛
________/~~~~~~~~*********~~~~~~~~\________
Certified delinquent LabVIEW developer. Recertifying at next NI Days
(3,515 Views)
Accepted by topic author bhushan191096
Hii szewczak
thanks for reply
but i didnt getsolution in any one of your shared links
My problem is solved. There is no need to use parameterized query for selecting values from control
In my case i want to display data from database where barcode no is same as entered by user
i use DB TOOL SELECT data function and create string condition by concatenate strings function
(3,474 Views)
