how to use matlab script node?
Hi everyone,
I want to know if there is a special syntax for the matlab node in LabVIEW and what are the capabilities of it. I mean can it handle a fuzzy logic matlab code?
I have a LabVIEW code that controls a pump connected to a microcontroller but this code should be conected to another Matlab algorithm(fuzzy logic) the algorithm is about 1200 lines. can such node handle this?
im trying to work on it since days but it always give me an error, the work flow goes like this, the inputs of the algorithm should be given in LabVIEW, the algorithm then should process them then the result(output) is used in Labview to do something...is this possible or not?
thanks!
(2,849 Views)
Hello valdi,
could you give me a few more details, please.
What LabVIEW version are you using and which error occurs?
Maybe sreenshots of the error and your program would help.
Stefan Stangl || AE Germany
(2,803 Views)
