how to use instr driver for TLA5202
I am using tektronix logic analyzer 5202B... I hav downloaded its instrument drivers from NI website... I am able to communicate with the instrument thru ethernet interface... now, i want to export the list file thru labview.... pls help me on how i can do that...
(2,747 Views)
What's a list file and where do you want to export it?
(2,737 Views)
once you do RUN in TLA, you ll get the signals data in listing tab... this data we ll export as a *.txt file in to some folder wher we intend to store this file...
(2,729 Views)
Assuming you mean the output of Read Acquisition Data, you can just wire the output array to a Write to Spreadsheet File function.
(2,716 Views)
HI! Santhu
Are you able to write the date to a text file or do you need any more resources?
Here is an example for you to write your data to a text file
(2,699 Views)
