how to use ex table to display string
工程師先生您好:
        在labview的撰寫過程中,遇到一個瓶頸想請教,使用Front Panel面板上的Modern→list,table&tree→ex table這個元件,敝人想要在table內顯示字串,但是table只能顯示數值。要如何在table元件顯示字串,或是有其他元件能像下圖一將資料顯示在Front Panel面板上,希望各為先進能不吝給予指點,謝謝。
圖一
(4,209 Views)
Translated with Google:
Dear Engineer:
Labview writing in the process, encountered a bottleneck would like to ask, use the Front Panel panel Modern → list, table & tree → ex table this element, I found myself inside you want to display a string in the table, but the table can only display values. Components in the table shows how the string, or other components can be like following diagram of a data displayed in the Front Panel panel, hope to hesitate to give instructions for the advanced, thank you
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(4,202 Views)
您好,
你的意思是不是很清楚。你可以尝试在这
此致,
Nitzz
(Kudos are always Welcome, Mark as a solution if it is the One😉
(4,189 Views)
really nice.i have attach one image. in this image inside i can't split tesxt cells.kindly explain to me sir.i will waiting for your reply.thank you sir.
(4,112 Views)
Hi britto,
you can't split text cells?
Splitting at comma is quite easy:
All the rest of your picture let's assume you only need some autoindexing loop a some easy string formatting...
(4,104 Views)
