how to use SQLConfigDataSource to create a User DSN of mysql 5.1
patchchen wrote:
hi, rolf
thanks your reply
as you said : You need to add an extra \00 at the end!
is that mean:
DSN=aa\00SERVER=localhost\00UID=patch\00PWD=patch\00DATABASE=bbb\00\00
if is yes, it still not work.
actually I checkd those parameters couple times before,and this time I do it again and show you the result, please check the picture file.
I can use the same parameters to created a ODBC driver by manually.
thanks
patch
Well I can't help anymore. Just one thing. If you have specified already a DSN with that name it might just as well fail because of that!
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 21 of 24
(1,738 Views)
hi,rolf
thank you very much, you indeed help me a lot.
this problem still not solve, hope anybody could help.
thanks
patch
Message 22 of 24
(1,722 Views)
patchchen wrote:
hi,rolf
thanks
patch
One extra remark! There needs at least an extra parameter "DRIVER=<whatever>" in that string. How should ODBC otherwise know how to invoke the corrrect database driver for your database?
Best is to simply create such a DSN entry with the ODBC Wizard and then look in the registry for the various parameters this DSN has to use.
Rolf Kalbermatter
Message Edited by rolfk on 05-21-2009 08:17 AM
Message 23 of 24
(1,696 Views)
hi, rolf
thanks your reply
you mean I should need to confirm the "DRIVER" name? I guess the driver name is "MySQL ODBC 5.1 Driver", because I use mysql 5.1 and many person thought should to use this who in the internet. so I always used in my program, please see the red circle on the attached file.
of course I had checked those registry parameters entirely before.
is that right? if I mistake your meaning please explain more clearly.
thanks
patch
Message 24 of 24
(1,688 Views)
