how to use Active X in LabVIEW
i m trying to acquiring the images from the ethernet camera. for this i want to use the ActiveX control.
but i donot know how to use this Active X with Image Acqusition.
(2,705 Views)
Hi ddsdds,
has your camera an ActiveX support? If yes, then use the "Automation Open" function, create a constant for "ActiveX Refnum" and select your type. Use invoke and property nodes to work with it. Don´t forget to close the reference if you are ready.
Mike
(2,693 Views)
(2,674 Views)
