how to update an array after every iteration?
I have a vi that runs fine but the problem is it updates all the data once the vi stops running. I want something like as soon as (for outer for loop) 1 iteration completes it updates the array in front panel, then 2nd iteration it updates again ans so on. Can anyone please help me with this.
Thank You
(2,662 Views)
You need to create a reference to the front panel indicator that you want to update. (Right click, create, reference).
You then feed this reference into the SubVI or loop where you want the update to happen.
Wire the reference to a Property Node and select the Value Property.
Whenever you put data into the value, it will update the referenced indicator.
(2,653 Views)
Accepted by topic author Hnagpal
Actually, in your case, there's a simpler way to do it.... if we're talking about the pink string indicator on the first loop.
Just move the Array indicator from oustide the loop to inside the loop.
(2,652 Views)
