how to uninstall MAX (Ver 2.0) after uninstall Labview 6.0
I have deleted the Labview 6.0 as well as NI-488.2. However, MAX 2.0 is still remaining and would like to know how to uninstall it. There's no program shown in Control Panel-Add/remove programs. And the remaining MAX doesn't work properly because missing some component.
(2,688 Views)
You should not be deleting files like that beause those are MSI based installers. Even if you delete the files, MSI stores a lot of information in the registry.
The only easily way for you to install everything that MAX 2.0 came with and then uninstall them all from ControlPanel>>Add/Remove programs. That should take away MAX as well.
hope this works!
(2,688 Views)
Thank you for your comment. I meant "delete" as "unintall through Add/Remove Programs". Anyhow, I installed LV again and then unintalled all. This time the uninstallation was working.
(2,688 Views)
