how to translate the text in the block diagram to japaneese language
 Hi all,
I have built a application in labview. All the lables and button names are in English.I want those to be in different language.
Particularly i have to give Japneese language support. I am using Labview8.0 on windows xp platform.
have been trying from 2 weeks. No useful sollution has come up. So kindly help me.
Thanks in advance,
Yogesh
Message 1 of 9
(3,777 Views)
you need this ?
Message 2 of 9
(3,773 Views)
see here
Message 3 of 9
(3,767 Views)
Hi Mathan,
Thanx for the reply. I got the sample vi from the link which u sent. But the lable is displayed with some junk data.
How to change my windows settings. What if it changes the windows text to japneese. I wil not be able to interact with the pc.
And how do i translate the text file to other language. Please give some example vi which i can run is LV8.0.
Yogesh
Message 4 of 9
(3,765 Views)
Hi yogesh,
                 Have you gone through this kb?
Message 5 of 9
(3,731 Views)
Howdy muks,
First I would like to thank you.
I have gone through the kb link.  After goin  through the same link I got  a lot of doubts which I have explained earlier.
The steps which I did-->
1)I have exported the strings.
2)I copied all the text in the text file and translated the same into Japanese.
3)And I copied the same(Japanese) into a new text file(with same file name as of the VIs). But its giving error.
I dono what to do. It would be helpful if I get any vi or the procedure to translate the txt file or the strings which I should I translate.
Yogesh
Message Edited by YogeshaYS on 08-24-2008 11:24 AM
Message 6 of 9
(3,723 Views)
 Can you specify what is the error u r getting?
Message 7 of 9
(3,693 Views)
muks,
Thanks for the reply.
Now I am not getting the error. I was translating the label and also the type of indicator. So it was giving control name mismatch.
Now I am not getting error, but, some junk characters are being imported though the data is in the text file. Do I have to do any changes in LV.
Yogesh
Message 8 of 9
(3,684 Views)
Hi Yogesh,
Please refer to this knowledgebase article for guidance on how to publish or run your VI in a different language only for labels, during run-time or previous to run-time. Choose the option that best fits your purpose. Also look at the related links section at the bottom of the article for more information.
Ipshita C.
Message 9 of 9
(3,658 Views)
