how to transform LabVIEW type picture to IMAQ type picture?
Hello everybody,
I have got a LabVIEW library, which makes AVI files from series of pictures. But unfortunately, as the input for the "AVI write" function, it needs the picture in the IMAQ format (not this blue line which means LabVIEW picture, but just pink line which means cluster). So IMAQ picture is a cluster, and I want to find a method for transforming the LabVIEW picture to IMAQ picture. Is it possible without buying any additional IMAQ libraries? (I have got only restricted number of IMAQ functions which were originally installed with LabVIEW itself).
TIA,
Yazilim
Message 1 of 11
(9,494 Views)
Yazillim,
Unfortunately, you are probably going to need the IMAQ library, unless you have the following (I don't know what you have because I have IMAQ): IMAQ Create, IMAQ Read ___(format, either tif, jpg, png, etc), IMAQ Destroy.
The problem is that IMAQ uses pointers, which is what the IMAQ image datatype is.
If your library that you acquired has the ability to read files, I would go that route instead of trying to input the pictures directly. The ONLY way to input the pictures is to read them from a file, or to acquire them through IMAQ, so you can see the problem you are going to have.
I would also suggest two things: Contact NI (ni.com/ask) and the person/company that made the library. They should be able to make a tool for you to read the
files into their library. Then, all you need is to purchase the runtime license for IMAQ.
Good luck.
Message 2 of 11
(9,492 Views)
Does anyone can provide the source code to solve the above problem?
Or any other reference available on the web?
Kai
Message 3 of 11
(9,315 Views)
Kai,
So you are trying to convert a picture that is a LabVIEW picture format into an Image data type? I used the Picture to Pixmap.vi wired to the Write JPEG File.vi, wired to the IMAQ Read File.vi.  If you let me know what version of LabVIEW you are using I can upload the example I wrote.
Christopher W.
Message 4 of 11
(9,292 Views)
Hi Christopher,
Hopefully, I did not mis-understand your suggestions.
However, I just can't achieve the task.
Please find the attached vi for your reference.
I am grateful if your can comment on my simple viSmiley Wink
(The vi only can convert U32 color video to jpeg individuel files.)
The broken wire was due to the IMAQ Readfile. (They are still not compatible)
I am using LabView 7.1, IMAQ 3.5.1 and IMAQ 1394 2.0.2.
Many thanks,
Kai
Message 5 of 11
(9,283 Views)
Kai,
Check out this example.  I wrote the file with the Write JPEG.vi but you could also use the Write PNG File.vi or the Write BMP File.vi.
Christopher W.
Message 6 of 11
(9,268 Views)
Christopher,
since my version is 7.0 express with imaq also 7.0. I can't open your demo.
would you please upload one file by screen copy which allow me to see
the diagram of your vi inner structure if it is only one layer.
It is urgent for me to know how to convert picture to imaq image also.
thanks very much.
tang
Message 7 of 11
(9,247 Views)
Tang,
I attached a screen shot of the block diagram.  It is very simple so you should be able to reproduce my example. Enjoy!
Christopher W.
Message 8 of 11
(9,224 Views)
Christopher,
Thanks for the picture. It works.
my question is if this is the way we have to work,  that's mean we need to
write this file to HD each time, therefore, for high frequence operation, this
may cause some problem for HD.
in fact, can we only read from memory without treat by write file? so this will
be faster and safy method. I hope to discuss with you for this issue.
tang
Message 9 of 11
(9,218 Views)
Hi Christopher,
The example is great.
This is exactly what I want to achieve.
Tonight, I can sleep well ... ...
Smiley Very Happy Smiley Very Happy Smiley Very Happy
Many Thanks,
Kai
Message 10 of 11
(9,193 Views)
