Greetings,
Unfortunately there is no way to pause the LabVIEW VI while your Citadel database is being corrected. Because Citadel has an seperate process from the LabVIEW process, you would have to have some sort of application monitor that process to determine if the database correction is taking place.
One issue that you may want to look at is, why does the database seem to be corrupted so often? Are you experiencing this sluggish behavior everytime you launch LabVIEW? In that case, I would consider reinstalling Logos on your computer. The newest version (4.4.0.17) can be found on our website or ftp. You should not be getting corruptions of the data with simply exiting or opening LabVIEW. Reinstalling the Logos should address that issue.
Have a g
ood day!
Patrick R.
