how to take output at different voltage
hi i have a vi in through which i want output at particular voltage for example at 1 , 4 , 7 , 11 volt instead of increasing voltage (1, 2,3,4..),what kind of input control should i use in while loop. please help. i have attached vi.
(2,665 Views)
Simply create an array of your random voltages and pass it into a for loop instead of your while loop.
(2,658 Views)
but i dont know how to creat array of random voltage .please me a demo vi.
(2,652 Views)
Then you need to see the basics here. You simply go to the array palette and first drop an Array Constant on the block diagram and then drop a numeric constant inside the array.
(2,641 Views)
thank you . i have already done it but it's not working.  should i put this array constant inside the while loop or outside.
(2,634 Views)
Accepted by topic author jkumar.1986@yahoo.com
Outside. And I said FOR loop.
(2,614 Views)
