how to sync pxi-6341 Analog Out to pxi-4304 Analog In
I have a PXIe-1082 chassis that contains a PXIe-6341 and a PXI-4304 module.  I'm outputting a sine wave from pxi-6341.Ao.0 channel to the pxi-4304.Ai.0 channel.  The pxi-4304 isn't capturing any signals until about 75 msec later. How do I sync timing between the 2 modules together to stop this loss of data?
(Eventually, I'll be running a digital waveform out of the 6341 and into a device while the 4304 captures analog response of the device. So I'll need to have everything sync'd up.)
Thank you for your help,
Ron
(2,848 Views)
Accepted by topic author mysticfree
After trying many "tricks" using various DAQmx VIs, I finally found the solution.  I simply had to stagger the "DAQmx Start Task" between the Input and Output as shown in the attached picture.
Hope this helps someone.
(2,798 Views)
