how to store the measured data in a new array
we want to put the measured data in a new array and then use this array to plot the SPC chart. Can anyone provide some suggestions?
(2,635 Views)
are you using some kind of data acquisition? If you reading in a loop you can build an array using the autoindexing tunnel (best way). Or you can use the build array function with a shift register inside a loop. Can you post an example?
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,635 Views)
