how to show the combo box, system checkbox and string in the multicolumn listbox?
Is it possible to show the combo box, system checkbox and string in the multicolumn listbox? I would like to build a cluster, but I'm not sure if it can be shown in the multicolumn listbox like below picture:
Thanks a lot.
WGQ
(6,095 Views)
that would be difficult....
There is an code on LAVA
Also if some .NET developer can design and give it to you, probably you can import the same in LabVIEW (i dont know how:(  )
Regards
Guru (CLA)
(6,006 Views)
I works great, but after compile it, when you click on the Boolean type, it cannot update the value.
Any one can give any suggestion, thanks.
(5,862 Views)
