hi ,
I build a test system of four UUT paralel test by Daq card 6220 ,scope and ac source......
but now the test time is so long(80s).
sample rate set 250000, sample (large signal set 10000, small signal set 100000)
my question:
sample rate should be set to max?
test time =sample/sample rate ,it seems sample rate set to max will be decrease test time. do you think so?
when I test small signal ,if sample set to 10000, the result are not stability,it must be set 100000, test time is 100000/250000=0.4s
I always feel that sample rate need not to be set max ,but how to set to improve speed?
Sonic
Diffrent Strokes for Different Folks
