how to select text in a stringcontrol
Hi guys!
Just a small question.
I got this string control in my FP:
Note that the text is selected (marked), like when you click behind the text and drag your mouse over it. (Hope I explained it right^^,) )
Well the case is, that I would like to do that programically. Let me explain:
Customer opens my program and the cursor starts to blink inside the string control. Then the customer use a barcodescanner on a barcode and then press START to run a test. After the test is done the customer is ready to scan a new barcode and run a new test.
Problem: After the first test the customer has to select and delete the number in the string control (105). Then scan a new code.
What I want: After the first test, the old barcode is selected(but not deleted) and the customer can just scan the new code which overrides the old one.
I looked for some property nodes, but not quite sure what to look for. I'm not familiar with all the names in LV yet.
Thanks and regards,
Even
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(4,928 Views)
Accepted by topic author EvenDeejay
(4,919 Views)
Perfect! Thanks alot:)
Even
Topro AS
Norway
(4,895 Views)
