how to select a region for analysis from a very big image
Hello everybody,
The imgaes recorded are very big, with 1288*964 in scale.  The regions I am interested is only a strip (say, (0, 400), (1288, 420) ) in the middle of the images. I need to anaylze the strip, and get some useful information. I  do not care other regions. and do not want to wast computer resouce.   I read some fuctions about ROI. should I use ROI?  To be honest, I have not understanded fully about the functions of  ROI,  and not fixed the problem.    I think my case is very general.      Could you please give me some suggesion ? or some relevant code examples?   Thank you very  much.
Beetle.
(3,017 Views)
Hi beetle.
Your previous thread already gave you some good advice where to start.  Have you looked at the Vision examples in LabVIEW?  As your previous thread said: "After installing the software, open LabVIEW and navigate to Help » Find Examples... » Toolkits and Modules."  You can also filter from the examples those that cover ROIs by searching with the term ROI.
7890000 wrote:
The imgaes recorded are very big, with 1288*964 in scale.  The regions I am interested is only a strip (say, (0, 400), (1288, 420) ) in the middle of the images. I need to anaylze the strip, and get some useful information. I  do not care other regions. and do not want to wast computer resouce.   I read some fuctions about ROI. should I use ROI?  [...]
Yes, ROIs are a good and the right approach.
Hope this helps, Guenter
(2,998 Views)
Hi Guenter,
Thank you very much. I will try
Beetle
(2,975 Views)
Hi 7890000, Yes, ROIs are best for your function.
-Make your four points in rectangle- Left,Top,Right,Bottom and angle (Might be zero if needed) bundle them using cluster palette.
-Convert your Rectangle to ROI using IMAQ convert Rectangle to ROI.
-Then use this ROI descriptor for further use.
-One more thing can be, Use your four points as input to Optional rectangle for IMAQ extract VI and after extracting the required region you can process.
uday
(2,965 Views)
