how to segregrate the strings from concantenates string
Hi
I am trying to write and read datas from the seral port using the VISA.vi with Labview . I am able to concatenate a number of strings for writing .I am able to read and write datas using the serial port .
I also want to read the value from the board and have to put a indication like the data that is written and that has been read by the serial port are same .
Plz give me one suggetion .
(3,015 Views)
Accepted by topic author electroncis
So u need to compare the witten value with the read value and needs to update the staus.find the attached VI.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(2,982 Views)
