how to save my 3 channel data like this
Hello,I need your help. I acquired 3 channel data.I have a push button called marker.When marker button is pressed it will be saved in a text file as 1 if it's not pressed it will be saved as 0 with other data.I think it will more clear to explain like below.I want that the saved data in a text file will be like this:(ECG,GSR,BR are my acquired data)
Time ECG GSR BR Marker
. . . . 1
. . . . 0
Message 1 of 16
(3,967 Views)
I was having problems putting "marker" after "time", but I hope this helps. You can open the text file in excel for spreadsheet form if you want.
Lauren
Message 2 of 16
(3,967 Views)
I couldn't open this vi because my labview is 6.0 which you sent is 6.1.Would you please send your diagram as a jpeg file.
Thanks for your help
Message 3 of 16
(3,967 Views)
Here is a picture.
Lauren
Message 4 of 16
(3,967 Views)
And I tried to save it to a 6.0 version, hopefully it will work with your version.
Message 5 of 16
(3,967 Views)
Thank you so much, this is what I'm really looking for.Thankssss
Message 6 of 16
(3,967 Views)
I have a problem. When I tried to combine my vi with yours there was a error. It says 'Array to spreadsheet String:contains unwired or bad terminal,you have connected two terminals of different types' I am not well experienced with Labview. Thus , I need your help at this point.You can find the picture vi below.
Best regards
Message 7 of 16
(3,967 Views)
Try attaching a picture again.
You might be acquiring with waveforms and that might be whats causing the problem.
Message 8 of 16
(3,967 Views)
here is the picture.You right I'm acquiring with waveforms,what should I do?
Message 9 of 16
(3,967 Views)
You can find the combined vi below
Message 10 of 16
(3,967 Views)
