how to save data to the USB memory stick using USB port on MyRIO
I am measuring the geomagnetism using a sensor called MPU9250 for MyRIO.
This geomagnetism data is three dimension data(x-axis, y-axis, z-axis).
Currently, the geomagnetism data is displayed on the waveform chart on the front panel
and manually export it to Excel.
I would like to save this geomagnetism data directly to MyRIO's USB port by inserting a USB memory stick
and directly storing the data in an excel file etc. created beforehand  in the USB memory.
Is it possible or not? If so, could you tell me how to create labview?
(4,761 Views)
Duplicate
Solution --> https://forums.ni.com/t5/Example-Programs/Save-Data-on-a-USB-Flash-Drive-connected-to-a-cRIO-sbRIO/t...
Certified LabVIEW Developer
GCentral
(4,753 Views)
whether this method also applies if using NI MyRio Hardware ? Thanks for your answer.
(3,337 Views)
What, exactly, is your question?  Rather than "hijack" a question asked (and answered) by another user, why don't you create a fresh question that describes your exact question?
  • What do you want to save?
  • What do you mean by "myRIO hardware"?  Are you referring to the Analog and Digital ports in the myRIO?
  • Where do you want to save the data?  Are you (also) planning to save it on a USB stick plugged in the myRIO Type A USB Port?
  • Are you sufficiently familiar with File I/O in LabVIEW?
  • Are you planning to have the data files "live" on the myRIO?  [Probably not a good idea].  Have you considered using the myRIO to collect the data (and control the acquistion) and streaming the data to the PC, which is ideally suited for saving (and analyzing) the data?
Please do not reply to this post.  Instead, start a new Post, ask a new Question and describe your situation and needs, as I've outlined here.
(3,331 Views)
