how to save data results into text file
I want to solve an equation of degree 2 for example, and results are displayed in a text file
Message 1 of 9
(2,852 Views)
Log it to a text file. Need a detailed solution explain the problem.
Message 2 of 9
(2,836 Views)
Sounds like a homework problem to me.
Message 3 of 9
(2,817 Views)
Say I want to do:
x = 1 +2
y = 5 + x
I want the text file to show me only x = 3 and y = 8
Message 4 of 9
(2,809 Views)
LabVIEW 101.
This is not a homework writing service. If you write some code and have problems with it, attach what you have done.
Message 5 of 9
(2,804 Views)
not homework this is an example i just want to know how to save that f........... resuts to an text file if you dont wann help me , dont ............
I thought it was a forum where you can be helped to learn......., but I see that you like more to judge  than   help, will seek help elsewhere....................thank you     :-q       ......!!!!!!
Message 6 of 9
(2,787 Views)
Oh, settle down.  Did you click on Dennis' link?  He did provide help.  He provided a link for you so that you can learn the basics...thereby helping you to learn.  Are you upset because he didn't provide you with a full working solution?  If so, that tells us something too.
LabVIEW ships with a lot of good examples.  Under the "help" menu, click on "Find Examples".  Then go to "Fundamentals".  Then go to "File Input and Output".  There's a lot of example code there that will help you.
Message 7 of 9
(2,781 Views)
You don't even have a VI of your attempt to solve this????
You just want to be handed the answer on a silver platter?
Message 8 of 9
(2,780 Views)
Like many other software coding forums, we don't want to give hand outs.  We are more than happy to give hand ups.  Show that you've tried to figure out the problem and show us where you are stuck.  Then we will be glad to help you get you unstuck.  If we just give you an answer, you will learn nothing.
As far as writing to a text file, look in the File I/O palette for the Write to Text File primitive.  Also, if you go to Help->Find Examples... and do a search for "text file" you will get some examples of how to use it.
GCentral
Message 9 of 9
(2,771 Views)
