how to save data in CSV format
Hi,Iam reading data continuously and I want to save this data in CSV OR excel format,please explain with example how i can do this as, iam a beginner.
(3,224 Views)
Use the function Write To Spreadsheet File on the File I/O palette. There is an input called delimiter. It defaults to a tab character but you can wire a comma string constant to it and get comma separated. Excel will read either comma or tab separated data.
(3,221 Views)
Thank u very much for ur reply,can u send me an example.I could not understant completely.
(3,214 Views)
Look at my attachment here. It has a Write to Spreadsheet File function with a space as a delimiter. Just replace the space with a comma.
A function like this is pretty easy to experiment with. All you have to do is open the VI, enter some data, and run it.
(3,206 Views)
Hofer,
Don't forget to search help when looking for how to do something. You will get some helpful results if you search for comma delimited. Unfortunately, CSV is a complete miss (I'll file that as a bug). Once within help, there are often links that will take you directly to an example and/or to related examples.
For example, if you hover over Write to Spreadsheet File (either on a block diagram or a palette) and then click on the Context Help windows ? button or "click here for more help" link, it will open online help on that function. Near the top of the online help is a link to an example.
You can also use the Example Finder (via Help >> Find Examples) when specifically looking for examples.
Enjoy,
Roy
(3,181 Views)
