how to save data from a while loop periodically
Hello All,
I have two while loops one running inside the other. the second while loop is continuously streaming data which I want to save to an excel file after every few seconds (12 seconds). I am using a 16 bit ADC. I tried using timed loops with iteration period as 12 seconds. I do believe there might be easier ways to do this. Could someone share their opinion on this?. I am attaching an image of the block diagram without any timing structure
Regards
Sud
(5,384 Views)
Saving data to a file is usually best done in a separate loop via a queue.
For an example of this type of structure, check the template:
File -> New -> Producer/Consumer Design Pattern (Data)
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(5,380 Views)
Why do you have the outer while loop?
If you want to save the data, take the other advice in this thread.  Set up a parallel while loop.  Use queues to pass the data from your acquisition loop (producer) to the secondary loop (consumer).  You can use whatever logic you'd like in the consumer loop to log the data.  You can log each point as you get them.  You can check for a number of elements in the queue before pulling them out and log it that way.  Log however you wish.
(5,361 Views)
It  depends on the data acquisition rate:
For high speed acquisition where data could be lost while processing and writing to disk use a producer-consumer architecture.
For low speed acquisition where there is time to process and write to disk before the next acquisition a simple state machine architecture works well enough.
=== Engineer Ambiguously ===
(5,343 Views)
