how to save appropriate images and then discard the saved images after using.
The attached program is used for gesture recognition and playing the corresponding audio file for each recognized pattern. It is saving all the images that are captured and is using in pattern matching. if pattern for "A" is captured ,then almost 10 to 15 intermediate images are captured along with pattern "A". If all are pattern matched then audio file of "A" will be played for 4 or 5 times which is not desirable. Also the images saved in the imaq write folder are getting piled up. They should be discarded after they are used up in pattern matching otherwise it would be a waste of system memory. Can anybody  advice in correcting.
Thanking you.
Message 1 of 1
(2,247 Views)
