how to save an image in a file
I have a program which acquires images and process them. How to save the image which is specified instead of saving all the images. I cannot give a timer option because the input images of interest does occur at the same time interval. I want to give a stop button and when it is pressed then only my image should be saved other wise it should not be saved.
How to program it.
(2,581 Views)
LV2011 version pls Smiley Tongue
Nghtcwrlr
(2,559 Views)
(2,548 Views)
You could just move your save code to after the while loop, but before you dispose the image.
GCentral
(2,536 Views)
I tried to bring the imaq write file 2 outside the loop but still the program saves every image. when it is stopped it shows error imaq write file -not an image.
(2,530 Views)
