how to run vi
hi
i m new in labview. i want to run my VI automatically means when i double click on my VI. i don't have to run it manually by clicking on arrow key to run it. infact i want to remove this bar from my application program.
(4,246 Views)
Hi
You can go to VI properties>>Window appearance>>Customize , there you can change display option according to your need.
For running vi when you open it, In VI properties>>Execution , you will find option for that.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,235 Views)
thankssssssssssssss man
u really solve my problem.
once again thaks for ur kindness.
(4,210 Views)
Removing the toolbar can be done in VI Properties => Window appearance
Kind regards,
Bjorn
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(4,196 Views)
Accepted by topic author nadeemalikpda
thanks man
(4,165 Views)
Then you should mark the message that helped you the most as the solution to your problem and not your own thank you message.  If you go to the options menu to the upper right of your message first, you'll be able to unmark it as the solution so you can go mark another message as the solution.
(4,162 Views)
