how to run evaluation version of PQA (picture quality analysis)
Hi, I downloaded the PQA software. I just want to run it in evaluation mode before decide to purchase. Could you tell me how to run evaluation version? Thanks,
(2,183 Views)
Hi testpqa,
It should prompt you to put in a serial number or allow you to continue in evaluation mode for 30 days. I recommend looking in the "readmeNIPQA.html" file from the download to make sure you made the correct order of installation, and then you should able to run for 30 days just fine.
Let me know if you are still having problems. Best of luck!
Nathan B
(2,168 Views)
