how to retrieve data from MySQL?
I have read Michael Aivaliotis's pdf document over at lavausergroup.com,
but his only example is for a command.
I want to retrieve data with a simple command like SELECT * from authors.
I have done this sort of thing before with Microsoft Access, and it's worked.
Also, I have read Microsoft's ADO document.
In the attached file, the returned RecordCount should be 7, but it is -1.
Any idea what is wrong?
(5,197 Views)
Hi nyc,
Try to set recordset's CursorLocation property to UseClient before opening the recordset.
Good luck,
(5,166 Views)
Xu,
that worked!
thanks. 🙂
(5,151 Views)
I have created a set of vi's that manipulate text strings to build up the query. I then write the query string to a temp file and run the mysql client in batch mode with the system exec vi. The command looks like this:
cmd /c
mysql -u $user -h $hostname -p$password $database < $tempfile.sql
This way you don't have to deal with the activeX and odbc stuff. ...or you could use the call library function node and use the libMySQL.dll directly.
here's a shot of my query vi
(5,132 Views)
I can't connect to MySQL database from LabVIEW. I have tested your LV_mysql.vi and I have changed the string connection and the query with mine but It doesn't work. I have configured the ODBC drivers from Control Panel.
What's the problem? Can anyone help me?
Toni.
(5,023 Views)
I have solved the problem error provider when I tried to connect MySQL with LabVIEW.
The version of MySQL ODBC 3.51 Driver (MyODBC-3.51.10-2-win.msi, version 3.51.10-2 doesn't work!!!) supplied by MySQL doesn't work with windows XP SP2 and LabVIEW 7.0.
I have downloaded earlier version of MySQL ODBC 3.51 Driver (MyODBC-3.51.10-win.msi, version 3.51.10) and it works very well, no problems.
The link for downloading the correct version is:
http://www.peterharvey.org/MySQL/MyODBC/MyODBC-3.51.10-win.msi
ToNi.
(5,001 Views)
