Hi Isn,
You
will want to use the Microsoft Word 9.0 Object Library to interface
with Microsoft Word. You could then potentially be able to use the ActiveX calls
provided to accomplish your goal. The specifics on how to do this
should be found in Microsoft's Documentation.
Refer to the Microsoft document entitled How to find and use Office object model documentation. In your case, you will be looking at the Vbawrd9.chm help file which I believe will be located in the C:\Program Files\Microsoft Office\OFFICE\1033\ directory.
Also refer to the Unable to Load Microsoft Excel/Word Help in LabWindows/CVI KnowledgeBase.
